Vortech V3JT on 18 A10 Questions
revinto7
NY
07 shelby-gt 14 camaro SS 1LE
1 can you run a V3 JT with 3.48 pulley on pump gas safely
2 can you run a flex fuel tune or do you have to run only E85 or Pump specifically with a supercharger.
What exactly is needed to run E85 with this setup
3 i would consider an 8 rib kit - Does it come with a good 8 rib harminic Damper .I hear the factory one is really designed for the safety of our oilpump gears -
IS THE 6 RIB good enough to reliably make 700-800 rwhp
4-- Beefcake I lost your number i was going to call you can you get it to me again Thanks .
5 what rpm /revlimiter/ shift points do they set the car up with with a supercharger. Also does drag strip mode and all the others still work properly after supercharger and tuning probably would use PBD to remote tune it .Thanks guys i know this is posted but it takes days to sift through all this shit but i want to do this soon .
Angry50
Jacksonville, FL
Fred
2017 Shelby GT350
1. you can they just pull more timing, IMHO better to go E85 first.
2. No flex fuel. will need E85 Tune and a 93 tune
3. the 6 rib is plenty to make that power. stock 3.6 pulley on E85 should be about 800whp
4. Number on their site
5. shift points set by tuner and their preference. drag mode still works but the tune will make the drag mode not needed. unless you have Magneride.
