- Sep 14, 2020
- Wellington, FL
- Jake
- 2022 F-150 RCSB 5.0
Hey all!
Vortech just released their Tuner Kits for the 2021 Ford F-150!
The long await Centrifugal Supercharger kit for the 2021 F-150 is here! They’ve utilized the proven V-3 Si-Trim supercharger, along with an air-to-air charge cooler to. The F-150 Tuner kit has been estimated to make 606HP and 596 LB/FT Torque with 8-10 PSI using 91 Octane fuel.
Of course, with more options in fueling and tuning coming out for the platform, we’re sure these kits will well surpass those estimates.On another note, Vortech carries that badass unique sound that only a centrifugal supercharger can make!
2021 Ford F-150 5.0L Tuner Kit Features Include:
- V-3 Si-Trim Supercharger (Self-Lubricated) with 3.40" Drive Pulley
- Billet Aluminum and Steel Supercharger Mounting Bracket Assembly includes Idlers, Drive Belt, and all High-Grade Hardware
- Air Inlet Assembly includes Mandrel bent 3.5" Aluminum Tubing, High Flow Roto-Molded Duct which mates to OEM air box and some aftermarket CAI assemblies, Silicone Sleeves and Reducers and Stainless-Steel Clamps
- Discharge Components includes Welded Air to Air Charge Cooler, Mandrel Bent 3" Aluminum Dis charge Tubes, Silicone Sleeves & Stainless-Steel Clamps and Recirculating Bypass Valve
Check out the Tuner Kits here!
https://www.lethalperformance.com/search/?q=vortech+2021+f-150
At the moment, Livernois Motorsports has been testing and providing tuning support for these kits, of which has seen nearly 180hp gains at the tire compared to stock power levels, all around at only 7-8 of boost. All done while maintaining stock fuel system on 91+ Octane fuel.
2021 F150 Vortech Supercharger system now available! Dyno results from Livernois Motorsports!
Check out the Livernois Complete Kit here!
https://www.lethalperformance.com/l...cal-tuner-2021-2023-f-150-5-0l-lpp945004.html
Of course, if you have any questions, looking for something in particular, or want to get something on order, feel free to reach out to any one of us here at Lethal Performance!
