Vortech and procharger ?s
kcc0521
Falls Church VA
Bo
2015 Black GT PP
Do the Vortechs still require an oil line or are they self contained now? How loud are the vortechs and prochargers now? I had an old procharger on my 92 coupe and it was obnoxious.
beefcake
Bethel
2018 Ford Mustang
vortech and paxtons have the v3 and 2200 offering in self lubricated
they also have many options in oil fed.
it's all personal preference, tapping the pan takes all of about 3 minutes, but you do have sl options if you don't want to
they also offer quieter and louder superchargers too
procharger kits are sl, they also have quiet or louder gear options too
we do more centri kits than anyone out there and can help you out with complete kits, tuner kits, or custom packages with lund tuning
kcc0521
Falls Church VA
Bo
2015 Black GT PP
Which charger is more efficient. I know the vortechs were more efficient in the past but it has been a while since I looked. Are there any advantages or disadvantages between the bracket setup on vortech and procharger?
beefcake
Bethel
2018 Ford Mustang
As far as efficiency, both companies will have different head units which will effect it's efficiency,
Example is, if you take a big ysi or f1 and stick it on a stock car that you only want to run 8 or 9 psi, you don't be close enough to the blowers peak efficiency for it to work well, Do you should want to run a v3 or p1. Or maybe the next step up
Both bracket systems I would say have potential to go really fast, we've been 8.17 " vortech s and would have no problem going 7s with a larger blower
kcc0521
Falls Church VA
Bo
2015 Black GT PP
I notice the vortech mounts the charger in the center and the procharger is off to the side. Is one bracket setup easier to install and maintain ( Like changing belts). I was leaning towards a whipple or roush but now I am thinking about a vortech or procharger. My goal is 650ish to the wheels but I might want to step up the head unit for more growth potential in the future.
beefcake
Bethel
2018 Ford Mustang
I get this question a lot, as far as "changing belts, and not really sure why
on the shared drive with a vortech / Paxton, you shouldn't need to change the belt any more often than you change the belt on your stock car, every 30, 40, 50k etc..
that said, it takes us about 15 minutes to change a belt.
on the dedicated drive of the procharger, thesupercharger belt itself should take just a few minutes
kcc0521
Falls Church VA
Bo
2015 Black GT PP
I had issues in the past with the belt on my shared drive vortech on a 96 cobra. I also had belt issues with an old procharger kit on a 92 coupe.
beefcake
Bethel
2018 Ford Mustang
We have 4.5 years and thousands of passes and have never lost a, belt.
With the current bracket system it should be a non issue
SVTFreak
#275
Prairieville, LA
2015 Wimbledon white LE #275 A6
That's the old days, man. I, too, spent many times on side the road changing belts in my powerdyned then vortech'd 95. Even slung a couple on my 03 until I fixed the problem. Used to have to keep belts in the trunk. Back then, a separate belt was a selling point due to being able to drive it when (not if) the belt slung.
It's not like that anymore. Rest assured that they have the belts sorted out.
On a different note, beef, are the vortech base setup (650ish whp target) self lubricated?
Barrel
Hoonigan
Cars and Trucks
I think the base setup uses the v3 which is self lubricated.
beefcake
Bethel
2018 Ford Mustang
He's v3 is sl
Mike@TBR
missouri
2015 dib pp gt
I had a vortech v3 on my 14 and now have a billet wheel jt trim on order from beefcake for my 15. HE is the man to go to for the centri setups and either way you go you will not be disappointed.
Barrel
Hoonigan
Cars and Trucks
Agreed. I bought everything except my MGW from him - including my PC stage 2. Top notch.
beefcake
Bethel
2018 Ford Mustang
as far as an "advantage", no, the cases are the same, just personal preference
