Uneven Stock Rear Wheel Gap
Albertcado
SoCal
2020 Mustang GT 6spd
Stock suspension and wheels, Steeda IRS subframe alignment kit installed, and the passenger rear wheel gap is 1/4 inch higher than the driver side rear. It's enough that it's quickly noticeable when you look at the car from the side. I can't remember if the gap was inconsistent when I first bought the car. The reason I had the subframe alignment kit installed in the first place was I had lowering springs on, and then I went back to stock springs. Knowing the subframe was moved and the wheels were not centered in the wheel well, I had the alignment kit put on to correct subframe position to factory, and have it in there for the future if I decide to lower again. But I have no idea how the one rear side is noticeably higher than the other.
Any thoughts? Could it be something to do with how the stock suspension/springs were put back on?
Do you need to reclock the bushings even when "raising" the car back to stock springs or is that just when lowering?
I was wondering if that could be the cause of the one side not settling down properly on the stock suspension.
