Turbo heat shield
doulos4jc
......looking^
2015 Turbo Mustang
Can shield be removed without taking everything else around it apart? It has me stumped.
stevnoof
new jersey
2016 mustang gt base manual 3.31
You need to pull off a cylindrical dampener down by the bottom of the heat shield in order to reach the torx bolt that holds the heat shield in place at the bottom. You will have to feel for the torx bolt it can not be seen from the top. To remove the heat shield you need to wiggle it around and deform it enough to slide out. The whole process is simple 10mins at most
doulos4jc
doulos4jc
......looking^
2015 Turbo Mustang
I already removed torx bolt. I got to the point of pulling out. Didn't want to totally destroy it trying to force it out.
khrome13
North Texas
2016 Eco Prem PP, 2015 F150 5.0, 93 Foxbody 5.0
You will have to bend it / straighten it some and really use some force to get it out. I was really surprised at how much I had to bend and pull to get it removed.
doulos4jc
doulos4jc
......looking^
2015 Turbo Mustang
I'm looking at some thermal wrapping/insulation of turbo and down pipe. Is that why you guys removed the heat shield? Got any tips on that?
khrome13
North Texas
I'm not sure what your question is... I didn't permanently remove the shield I took it off to replace the WGA with a different one. Then I put the heat shield back on.
doulos4jc
doulos4jc
......looking^
2015 Turbo Mustang
See post #5. I will put it back on.
