True or False - Used tires cannot be Road Force Balanced
MRRDesignWheels
Los Angeles
Mustang
yes you can road force used tires, all it is is a more detailed balancing
a more true balancing that it allows to see exactly how the entire assembly will act on the road. but with used tires it will have it's limits/ I mean the process can be done but the outcome is more exact on new tires thats all.
  • Like
Reactions: GTP
jasonstang
Denver, CO
2017 GB GT/CS 6MT
Tires wear unevenly so a used tires would have uneven spots already making the road force balance difficult I assume.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
Correct Thats why if its a hunter road force touch they can do a match 180 procedure to ensure the runout reads out properly.
VinnAY
Kansas City
18 Camaro 1SS/1LE
I believe that that's the reason right there.
GTP
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
Please explain.
So this process is when they match the high point of the tire with the low point of the wheel. now this is something ive seen done on new tires. That being said it may be more difficult on used tires, but it may also be possible.
[ame]
