Tri-Bar LED stock Flicker Issue
West Florida
Nathan
2017Mustang GT Premium
Looking for any help before I consider dreaded dealer. I noticed that my tri bar LED's on passenger side are flickering . The actual headlights, fogs, etc are working fine. Can't find much on this happening to stock tri bar drls . Any idea what the issue could be ? Works fine sometimes and sometimes slight flickers .
gmupatriot
Northern VA
2018 Mustang GT (Orange Fury), 401A, A10, 3.55
Its possible the module which controls the DRL's is on its way out. It plugs right behind the headlight assembly if I am not wrong. Hopefully someone who has dealt with this issue will jump in and point you in the right direction.
What you are seeking is in Post # 25 of this thread:
https://www.mustang6g.com/forums/threads/tail-light-out-then-back-on.101551/page-2
2 more items of mention for you:
1) If the vehicle is still under the 3/36 bumper to bumper OR an extended Ford ESP plan (with LIGHTING coverage), any taillight malfunction is covered by warranty. The same applies for Ford TSB or SSM’s, they revert to warranty provisions and work/replacement is free of charge. If the vehicle is out of warranty, an existing TSB or SSM is performed at Dealer discretion and depending on Dealership, you can be charged for parts/labor. If you feel you should not be charged, contact the Ford 800# and refer them to the TSB or SSM to prove it was an existing issue and sometimes they will work with you.
2) If the vehicle is out of warranty or the part won’t be repaired under warranty provisions - the 2015-2017 rear taillights can be had for $400-$500 for a pair on this site in the classifieds section OR expect to pay about $150-$300 per light depending on who’s selling. Also you can look these up on eBay - there’s a TON of them for sale ranging anywhere from $150 each upwards of the Ford retail of $800-$900+.
Don’t pay retail for any S550 rear taillight....
The tails are LED operated by internal circuit board inside of the light assembly.
West Florida
Nathan
I appreciate the detailed response however the issue is not the tail light it is the front headlight triple bar "gill" drl
