Tread width versus wheel width
Performance nut
TX
2018 Mustang GT A10
Was looking on Tire Rack for tires for my non-PP GT (18" wheels) and came across Bridgestone Potenza RE970AS. Was curious about if the 255/45-18 tires would fit. It says it will fit an 8" wheel but the tread width is 9". Wondering if that was a typo or if the large aspect ratio allowed for a more narrow wheel.
Near identical specs as the stock tires, just a bit wider.
http://www.tirerack.com/tires/tires.jsp?tireMake=Bridgestone&tireModel=Potenza+RE970AS+Pole+Position&sidewall=Blackwall&partnum=545WR8RE970PP&tab=Specs
Texatl
Insensitive jerk
Ohio
2017 V6 Prem, 6spdMT, Lightning Blue
In the "specs" area (while looking in the tires details) it should say the recommended wheel width for this tire. Usually gives it in a range (if capable).
I would say it maybe sounds right, maybe. 8 inch might be a tad small, depending on tire specs. My 255/40/19 pirellis (stock p-zeros) say 8.5-10. But I highly doubt that tire would be ok on a 10 inch wide wheel LOL. And the stockers are 8.5.
scoggy_doogan
2016 GT Premium
Stock wheels are 18x8. Tirerack says a 255/45/18 should fit the stock wheels. I've yet to see any pictures of the setup though.
A higher aspect ratio allows for a wider tire on the same width rim.
