Transmission fluid whoa
Performance nut
TX
2018 Mustang GT A10
Just bought some transmission fluid service using Amsoil from one of the local reps only to find out he doesn't have the machine necessary to do the swap. Is Ford the only place you can do transmission fluid swaps at? The price quoted just to use the machine is ridiculous.
ahl395
Allan
Find a mustang or performance shop, they should be able to do it.
ronemca
ON Cda
Ron
2016 P/EB w PP
This phrase seems peculiar. Do you mean you bought fluid or do you mean you bought a procedure?
If you're changing the tranny fluid, you don't need a machine; just a big syringe (or an inexpensive manual pump of some sort) and a container for drainage. Warm up the tranny...raise the car...remove the fill & drain plugs (in that order) and away you go.
ahl395
Allan
hson10
SF Bay Area, CA
www.instagram.com
Hans
2017 Grabber Blue Mustang GT Premium 6MT
I ended up buying the BG Synchroshift II from Optimum that came with the pump and even a leftover cup that you can use to measure exactly how much fluid to pump in. On jackstands it took about an hour to drain and then maybe 15 mins to fully pump in. MT82 car, I think just for the sake of convenience I'd just buy this kit next time I have to change the trans fluid again.
