Wilbs
Hi.
I had a problem with a tire pressure sensor, rear driver side tire keeps coming up with 'Tire sensor malfunction' on the dash, Once I've reset them in the settings menu it begins to start showing the psi on that wheel again on the menu display, but after around 20mins it comes back with the same message, cars only done 1200 miles. One thing I will try tomorrow is to put air in the valve and see if that helps the problem, anyone had a issue with these in the past?
Looks like I may be ringing ford service tomorrow morning :(
Thanks
Thanks
