Lantastic
Hello all! I have a quick question regarding making touch up look as good as possible. I have about a pea sized blemish/chip, part down to the primer and part down to the metal. I've tried fixing it with a couple of different methods without much success.
First I tried a technique "borrowed" from a drive clean video, filling the chip and then wet sanding it down to be level with the existing surface. I'd done this before with a much smaller chip and it worked out quite nicely. But the problem with this chip is that it's too big, and sanding dulls the touch up so it no longer matches the existing paint. It's magnetic metallic, and touch up, so I understand it won't be perfect. But perhaps there is a better way. This stuck out like a sore thumb! Is this always the case with touch up? Or am I just SOL with this being metallic paint? FWIW I my touch up is not OEM but when tested on a discrete area it matched well. The sanding makes it much worse. Perhaps it is just this particular brand of touch up.
Second, after sanding out the previous touch up, I tried covering the area with as smooth of brush strokes as possible. I was able to wipe of the excess with an old t shirt and some rubbing alcohol, as to not make the touched up area any bigger than necessary. I felt this worked pretty well. But even the alcohol discolored the edges of the touch up. And of course there are slight brush marks and unevenness I would like to eliminate.
I know it can't be perfect. And it's a daily driver. So I'll have to live with chips. But I'd prefer they be well touched up chips! Any advice would be appreciated.
