Torsen IRS Troubleshoot to Resolve
Bahndvr
Roushcharged
Germany
'16 Roush Warrior Mustang
I drive my Stang hard. The pumpkin has barfed out all three holes. So what would cause this? What can I do to resolve it? I have the Full-Tilt-Boogie cooler to install but is there anything else I need?
I know that there is a seal for the front (pinion) I have a new one to install but the driver's side and passenger's side are there seals to be replaced there too?
Thanks
The side seepage at the axle seals is pretty much normal, that could be seen on brand new S550’s after a few miles. Spray down the housing with carb cleaner to remove a lot of the residual, then go for a 10-20 mile drive and see if it comes back and if it does to what extent..
Is the rear leaving any liquid on the ground at your home where the car is usually parked? Is the underside of the car chassis saturated in gear oil? If the answer is no, then it’s not a real concern.
Bahndvr
Bahndvr
Roushcharged
Germany
Answer is yes. It's coming out of the front (pinion) and running toward the center. So change the front seal?
Yes, if it’s coming from the pinion seal for certain, you’re going to need to change it.
If you haven’t, I would still spray down everything with some cleaner, wipe dry with a shop towel or microfiber - go drive it and see if it’s definitley coming from the front pinion seal.
Bahndvr
Bahndvr
Roushcharged
Germany
It's definitely coming from the front.
Drops will collect after a good run under the front snout.
ObnoxiousGt
SC
2015 S550 GT / 71 TORINO
Was following your conversation. Have you replace the seal yet? If so, did you dis it yourself? I am in search of some instruction how to change my own.
Bahndvr
Bahndvr
Roushcharged
Germany
I have not replaced the seal yet. (I'm just procrastinating) I will do it myself. I have the Ford tool to remove the yoke.
It's not hard, mark everything. Impact wrench is Not recommended. I will figure something out to install the seal evenly.
ObnoxiousGt
SC
What is the ford tool used to remove the yoke? Where can I get one also?
Bahndvr
Bahndvr
Roushcharged
Germany
Bahndvr
Bahndvr
Roushcharged
Germany
Sorry special tool to install the drive pinion flange
Special Service Tool: 205-233 (T85T-4851-AH) Installer
At Freedom Racing
I don't know if you want to drop the coin for something you might only use once.
To hold the pinion flange from turning I'll figure something out (a bar with a couple of holes to bolt up to the flange should work) and then a pulley puller to pull flange off.
nbjeeptj
Gilbert SC
Neill
2019 Mustang GT
An old school y shaped harmonic balancer puller will get it done, It is what I think I ended up using to pull the yoke.
atomicpunk
Philly burbs
Sean
2020 GT PP1
All 3? I would pull the vent off and make sure it's clean or maybe it was over filled?
