Tomtop Bezel + MyFord touch Screen
pumxee
Calgary
Hamza
2016 Mustang v6 DIB
Does anyone know if the Tomtop Dash bezel will work with the OEM MFT screen? As in just fitment.
zackmd1
Zack
It will likely not work. The screen ratios are different, 16:10 vs 16:9 if I remembered correctly. That means the TomTop bezel will not have a big enough opening for the MFT screen. I researched this as a possible solution to the MFT swap bezel problem due to the tomtop unit being cheaper then manufacturing just a bezel.
pumxee
Calgary
Hamza
2016 Mustang v6 DIB
Zack,
In the regular base models bezels. Your MFT bezel on shapeways. How does that install exactly? I was thinking about getting that and buying an MFT display
zackmd1
Zack
Zack,
Your OEM bezel will have to be cut and my bezel installs either by adhesive tape or believe it or not high temp hot glue. I used hot glue during my prototype stage and it held up surprisingly well and was very strong.
aggieStang
Refugio, TX
2015 Mustang GT, 1965 Mustang Coupe
Just as a side note if your hot glue gets anywhere near 210*f, it works really well on most plastic because it can actually melt the ABS. I have learned this with my attempt with 3d printing PLA and ABS.
