Put more space between the throttle body and the upper intake manifold= I was curious as to what a throttle Body Spacer would actually do =
I've never seen an instance where increasing plenum size resulted in higher torque at low engine speeds....carb'd or injected.Spacers usually increase low/middle range torque which isn't something we need, lol.
Yeah, that's runner length no?I've never seen an instance where increasing plenum size resulted in higher torque at low engine speeds....carb'd or injected.
Read this.I've never seen an instance where increasing plenum size resulted in higher torque at low engine speeds....carb'd or injected.
This is what Boomba said in Post No. 13 from the link above:Yeah, that's runner length no?
That's incorrect. Pseudoscience. Look at post 10 of the same link...Read this.
"Essentially the spacers add volume to your intake plenum. This has been shown to aide in cylinder filling at lower RPM, smooth out throttle response, build boost sooner, and lengthen the effective wave pulse of the intake charge. In the picture shown above, you can see the dyno charts of both spacers paired and the gains are tremendous. Over 30 ft lbs of torque (in using both spacers) and a significant change in the horsepower curve.
We are strapping the Mustang to the dyno today and expect to see similar results!"
^thisThe best use of a spacer would be as an injection port for a meth kit or similar. .
Do you even read what you say yourself? You said, "I've never seen an instance where increasing plenum size resulted in higher torque at low engine speeds", so I provided a link showing you where it added 'torque' at lower rpms according to Boomba's dyno sheet! I didn't say that it was sound science, and even went so far as to say that it's best use would be as an injection port for water/meth or similar. I personally wouldn't spend my money on just a spacer, but if I wanted to add meth at the throttle body, that'd definitely be an option. :shrug:That's incorrect. Pseudoscience. Look at post 10 of the same link...
Complicated explanations do not equal truth.
'Lengthen the effective wave pulse of the intake charge'...sorry, but that is a collection of words that don't mean anything with respect to even lengthening intake runners, much less increasing plenum volume. It's quite literally nonsense.
Caveat emptor
Thanks for repeating what I wrote. You may wish to reread what I wrote yet again, for good measure. In the 'test' you linked to, Boomba admits to having changed both TB and IR spacers. That's two variables that could be the reason for the 'gains' (which is debatable in itself). Mathematics leads us to the conclusion that the IR spacers are the reason for the shift, not the increase in plenum volume.Do you even read what you say yourself? You said, "I've never seen an instance where increasing plenum size resulted in higher torque at low engine speeds", so I provided a link showing you where it added 'torque' at lower rpms according to Boomba's dyno sheet! I didn't say that it was sound science, and even went so far as to say that it's best use would be as an injection port for water/meth or similar. I personally wouldn't spend my money on just a spacer, but if I wanted to add meth at the throttle body, that'd definitely be an option. :shrug:
