Dean McQueen
- Jan 2, 2025
- Independence, Mo
- Dean
- 2015 Mustang
Hey, i'm pretty new to,forced induction also. Can anyone tell me which wires to hook a volt meter to to get the TPS2 voltage to adjust to .40-.45 volts. 2112 limp is really getting oldThere are the throttle position sensor voltages(TPS 1/TPS 2) that need to be correct for it to go to the correct commanded angles. Determined by the position of a magnet fixed to the rotation of the throttle.
If they are wrong you can get problems ranging from idle/ drivability issues to throttle stuck Codes, not really what you are describing. Its hard for me to imagine that magent came loose on a stock TB.
Look up a whipple throttle body PDF for TPS 2 forced closed voltage range. .4v-.45v when forced closed iirc.
Can't hurt to check it, but throttle control is probably not your issue.
Get a log of the car peforming well, and one of it not performing well, compare to see what changed.
