- Sep 14, 2020
- Wellington, FL
- Jake
- 2022 F-150 RCSB 5.0
Ford Performance has just released their re-designed CJ Manifold for the 2011+ Mustang GT's! Made from lightweight composite material, Improved lid stiffness, Tuned Runners, and tested to 20+ PSI, this is the Ultimate CJ Manifold, whether your All Out N/A or Big Boost!
Available in Standard as well as Ported from @1320junkie !
Check it out in the link below!
https://www.lethalperformance.com/search/?q=cobra+jet+intake+manifold+5.0+
Developed and based on the naturally aspirated Cobra Jet Race Car, this intake manifold is one of the most popular modifications to 5.0L Coyote-equipped racers and enthusiasts.Available in Standard as well as Ported from @1320junkie !
- Fits 2011-2014 Mustang GT with manual transmission and 2012-2013 Mustang BOSS 302
- Fits 2015-2022 Mustang GT with manual transmission and with modifications including but not limited to-hood clearancing (modification to stock hood), and/or aftermarket hood and/or lower engine mounts
- Significant power increase over M-9424-M50BR Ford Performance BOSS 302 intake manifold, with no loss of torque
- Made from lightweight composite material
- Improved lid stiffness
- Runners are tuned for 7750 RPM peak power
- Designed and tested to 20+ PSI
- Intake gaskets included
- Compatible with production Mustang GT 5.0L fuel rail
Notes:
- Requires Ford Performance M-9926-CJ65, M-9926-MSVT,or M-9926-SCJ Throttle Body
- Requires Ford Performance M-9444-M50B Installation Kit for installation on Mustang GT 5.0L (inlet hose included in installation kit is not used
- Requires Ford Performance M-9603-M50CJ Cobra Jet Cold Air Kit or equivalent to mate to oval throttle body
- Cobra Jet inlet tube does not have provisions for aspirator tube hook up found on automatic transmission-equipped Mustang GT
- Intake manifold is not compatible with original equipment or Ford Performance strut tower braces
- Nitrous oxide not recommended for use with this intake manifold
- Calibration is necessary to prevent engine damage! Calibration not included!.
