Sway bar movement? Lockouts?
zrain25
Nh
Zachary
2019 f150 2021 mustang gt
Was finishing up steeda extended ball joints and bump steer kit putting everything back together, when I noticed it looked like my sway bar on the driver side was pushed over more then the passenger side. Now my car is 21 gt pp1 with magnaride. I upgraded the front sway bar to oem gt350 front bar. It seems to be moving laterally. I did use teflon tape and grease when I put the gt350 bar on. The original pp1 bar was basically glued on, should I have glued the gt350 bar instead of greasing them. I was able to kick it over an inch. My only concern is if it shifts under load which it will it looks like my magnaride wires in the strut will hit the sway bar end links witch ever side it shifts to when turning. Anyone run into this issue
TopJimmyCooks
Raleigh, NC
James
2017 GT Prem PP; 2019 EcoBoost Prem
I had the same issue. Used some rubber strip with a hose clamp around it on the bar outside the edges of both brackets.
