Sway bar lateral movement
BrantMcE
Tampa, FL
2015 Mustang GT Premium Magnetic w/ Dark Saddle In
I recently installed the Whiteline rear sway bar and endlinks kit. After a few miles on there has begun to be a lot of clunking coming from the back. Looking at it, it appears the sway bar is shifting laterally, quite a bit causing the end link to make contact with the spring. I've got the lateral locks installed on the bar however it doesn't seem to help prevent the lateral movement. Anyone have any suggestions on what I might be able to do to prevent it from shifting so much?
Thanks,
Brant
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Thanks,
Brant
Are the lateral locks slipping/sliding?
BrantMcE
Tampa, FL
Yes, I've screwed them down tightly however, it is aluminium and the install video said not to over tighten as it would likely strip the threads.
BmacIL
Enginerd
Naperville, IL
Loctite on the threads? Also may want to look at hydraulic loctite between the lock and bar.
BrantMcE
Tampa, FL
Never heard of hydraulic loctite, I'll have to look into that. I'll give the threads some thread lock though. I was debating on drilling a small hole through the sway bar to put a bolt through to use as a lateral lock if all else fails.
BmacIL
Enginerd
Naperville, IL
