Sway Bar Adjustment
Bob_Whit
Menomonee Falls, Wisconsin
2016 GT Premium PP
Hi Guys
I have lowered my car about an inch, it's a daily driver.
I'm thinking of getting the Drake adjustable end links. How should the sway bars be on the ground with the car weight? Right now I would think they have preload just from the lowering, should they be parallel to the ground to work correctly, as intended?
Thanks
Rebellion
Houston
2016 Competition Orange GT
Hi Guys
Thanks
Not necessarily parallel. To start, set both links to approx stock length, install one side, then the other...make small adjustments to length of the second one so the bolt end of the link lines up perfectly with the bar's hole. Obviously this is with the car loaded on all fours, basically you want the end links to be at the exact length so it there's no tension/compression on them.
