Melbnut
- Mar 3, 2015
- Melbourne / Australia
- Mustang gt
did you order today
Ok, in the interests of adding something to this discission - lets do it.Still learning about all this stuff but from what I have been told from KW, H&R, Eibach, & Shockworks, all coil overs do not work the same way when you adjust the height. Some models of coil overs adjusts the damper only without any compression on the spring, whereas the Eiback Prostreet applies compression on the spring and further firms the ride.
I know JS about coil overs and I'm in the process of learning the pro & cons of the different model of brands and why they differ in price.
This is good video to explain what I'm referring to, explaining the difference between a slip fit coil over and a full bodied coil over:
Bilstein will be releasing their coil over in September/October this year. The PSS10 would be a great kit.
If you look at the shock in that picture, it's at full extension.
Now, let's imagine that the bottom collar is adjusted so that the spring is only just resting on the adjustable platform.
Place weight of car on top of strut.
Spring compresses to X length.
Winding the bottom collar downwards will allow the spring to move downwards. NOTE, the length of the compressed Spring will NOT change, because the car is moving downward at the same rate that the spring perch is being lowered. The ONLY compression being applied to that spring is the weight of the car.
The tradeoff is that as you lower the car, you're giving up strut length (damper travel).
To counteract this, some manufacturers will offer a full threaded body that goes into the bottom mount (we'll call it the spindle). By allowing more of the body into the spindle, you're lowering the car without sacrificing damper travel.
The other thing to note is that the Eibach spring has no "float" even when the bottom perch is at its lowest point.
If however you were running some seriously heavy springs eg. Springs that compress very little under the weight of the car, they would be shorter by nature and would rattle when weight is removed from that corner.
This is where having the adjustable spindle height comes into full effect, allowing you to snug the collar to the short spring and lower the vehicle by letting more of the damper through the spindle.
I really hope that makes sense.
Mate, I'm no guru, honestly.Ok so you seem to know what you are talking about. So given i need advice what would you do if you wanted springs only at this stage?
The Eibach Coilover is about the only thing on my radar at this point.Sounds like you know what you are talking about Burkey I do not disagree with that. The contribution I have provided is from the SME, so please do not shoot the messenger. One of the SME was John from Eibach.
So what coilover brand/s have you narrowed it down to?
Mr MM also ended up wiping the car out hehe. That said, I've run Shockworks coilovers in my 86 for about 3 years and done some pretty decent track times.Shockworks also do good stuff by all accounts, but it's another $800 (maybe more) and I'm not convinced that it will really offer anything to ME that I can't get from Eibachs solution. They can however offer custom spring rates and valving. If I was a trackaholic, they'd be firmly in my sights.
If they're good enough for Mr. Mustang Motorsports, they should cover most people's needs.
why cant there be someone in melb who wants to test a kit. On my car damnitSpeaking to a mate yesterday, MCA need a car in QLD to help with testing of their kit and finalise specs for production.
Anyone serious about coilovers up north should definitely give them a call and work something out. I'm sure they'll look after you too.
I wonder if Chev's or HPF are doing any work on the stangs...why cant there be someone in melb who wants to test a kit. On my car damnit
Hey Guys
Anyone running with Steeda progressive sport springs, I have a set ready to go on which I will be doing next weekend. Just wondering what they are like, and what difference it makes to the feel of the car :shrug:
