Super upset... 12.9 @ 112.8 mph
Viperbluecobra
Houston
2015 Mustang GT Base PP Recaros
The god damn wheel hop was horrible!!!!
I had to baby it off the line and the 1-2 shit spun bad and wheel hopped even more and let up on the throttle. All 4 passes were like this. :frusty:
I had 04 cobra and it wasn't this bad at all.
Ford has something seriously wrong here. :paddle: The fact I can't take this car to the track and enjoy it is ridiculous. :mad:
60ft - 2.05
1/8 - 8.49 @ 87.87 mph
1/4 - 12.912 @ 112.82 mph
Mods - JLT Cold air intake, Lund tune from beefcake, and MPBR street cat back system.
RevvdMedia
Canada
2015 Mustang GT Premium
Sounds like I should buy that rear subframe bushing kit ASAP. Me no likey wheel hop.
Mikeg4572
Scottsdale, Arizona
2015 Magnetic GTPP
I would still be happy with that time. I couldn't beat 13.5. Was hopping on the launch and the 1-2
mdnt
Albuquerque
15GT/PP RubyRed
atleast with 112 mph the power is there. how was track conditions?
Tommy V
Brookly park Md
Tommy
60ft - 2.05
Drag radials would make the car launch completely different.Get some stickys.
tj@steeda
Timothy
I think Steeda can be your friend
David@Steeda will be happy to get you dialed in!
Best Regards,
TJ
Juben
Chattanooga, TN
Justin
2015 EcoBoost Mustang (AT) w/PP
How are you launching? Are you preloading the suspension? I've yet to have any wheel hop, even with launching under boost.
Viperbluecobra
Houston
What is pre-loading the suspension? I launch slipping the clutch a little bit as well as balance how much throttle, usually starting at about 2,500 rpm. Pending on how the car leaves is how much I do of both.
Track conditions. Track was well prepped, as they were having an event on Saturday, so Friday night became the test night.
Weather wise, it was about 76 degrees. After about 930 the dew point hit and you could see moister on the cars. Not sure on the DA or humidity. Someone can look that up, I don't know how? It was friday 4/3, Royal Purple Raceway in Baytown, TX.
Steeda and BMR seem to be offering solutions, just not sure which one to go with yet.
David@Steeda
United States
www.steeda.com
David
Bolt-on, slammed S197
Here to help with any questions! A good starting point would be our IRS subframe bushing support system and subframe alignment kit - feel free to check out some of the reviews.
Next would be vertical links and rear IRS subframe support braces. These items will absolutely reduce wheel hop at the track :)
Five Oh Brian
Mustang Guru
Pacific NW
www.KorumFord.com
Brian
11 GT500 Glass Roof Coupe
Automatics are much less likely to wheel hop; the torque converter absorbs the launch shock much better than a clutch.
smokinzx14r
ST Petersburg FL
Lee
2015 GT A6 3.55 Gears ..
Steeda bushing help me with the wheel hop .. I didn't fix 100% of it but they do help ..I'm looking at adding the Steeda sub frame support braces soon ..
Clink
'14 Focus
Where'd you run your times at? Bradenton?
Viperbluecobra
Houston
