Strange tire issue
PamAndJim
DFW
2015 EcoBoost Mustang
I got in my car this morning and noticed that the screen in the dash was lit up with a low tire warning. It said my left front tire was at 25 lbs compared to all the others, which were at 27 lbs. I figured a couple lbs wouldn't make much of a difference. So, I headed to work with the intention of stopping at a gas station and putting some air in. Here's where things got weird. I pulled up to the compressor and with the help of a tire guage confirmed that the tire was indeed down a couple psi. So, I hit the button and proceed to air up the tire. After holding the nozzle on the valve for a few seconds, there is no change. So, I push the nozzle back on and hold it on there for twice as long. When I test again it's at 18 lbs. WTH??? I think to myself that maybe the compressor was broken and head to work, which is like 30 feet from the gas station. At lunch I took it to another nearby gas station. I now that compressor was woking because I watched a guy in a Charger air up a totally flat tire. So, I give it another whirl. After holding the nozzle on for a couple seconds again I tested it... 17 lbs. Uggh. Somehow the tire is letting air out, but none in. The seems to holding air because it was at the same level as when I parked it this morning. So, I don't think it's leaking. It's almost like the valve is just not letting the air in. Could that be the case? Could there be something wrong with the valve itself? I know that I'm no mechanical genius, but I am fairly confident in my ability to air up a tire. Although, I guess it's possible that there is some sort of user error involved. Please help.
VinnAY
Kansas City
18 Camaro 1SS/1LE
Entirely possible that the valve stem is faulty, not letting air in but still able to hold air.
PamAndJim
PamAndJim
DFW
If that's the case would the TPMS sensor need to be replaced? Or can you replacr just the valve stem? Another possibility I'm finding online is a faulty valve stem core. It sounds like can be swapped out pretty easily. Are there any tricks to replacing that on a TPMS equipped car?
stangbro
SoCal
Wiggle the valve stem when trying to put air in it. A valve core is quick and easy to replace.
PamAndJim
PamAndJim
DFW
I did try wiggling it, to no avail. I'll stop at the parts store on the way home and grab a core and tool to replace it.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
A core is cheap and simple to change, it may just be that bad core. Shouldnt be more then $10 bucks to do.
PamAndJim
PamAndJim
DFW
$7.49 for the tool and 5 cores to be exact. Swapped it out and is well. Thanks all for your help.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
