gtcrackers
Where can I find a stock rim for the front of a GT 350?
No. Actually it's called the "search function" in mustang6g forum and the internet LOLYes is called mustang6g forums.
Yes, and if you use OEM GT350 rear rims with GT350R front hubs and 38mm spacers, you get exactly the same fit (OEM lug nuts work) and 24mm offset as an OEM GT350R front wheel. It's almost like Ford intended it to work this way.Does anyone know if you could run two rear wheels on the front with spacers/extended lugs to go square? Not sure about the backspacing and offset.
Looks like an OEM style and the notation on the rockauto site says "reconditioned."WOW. $125ea?!
Hmm
Yeah - I did notice the reconditioned. I'm just thinking -- at $500 for the set - might be worth grabbing those and throwing all season on for next winter.Looks like an OEM style and the notation on the rockauto site says "reconditioned."
WAAAAAAA! Do you need someone to tie your shoes too! ; )Thanks for the info on Rockauto.com. Thanks to all those that are helpful on this site! It always seems to amaze me that some behind the keyboard would rather do otherwise!
