Stock Engine Oil & ATF Cooler Locations
gjpundsack
Scottsdale, AZ
www.thewaltermittygarage.com
Gary
2017 Mustang GT 5.0; AT; 355's
Where is the factory engine oil cooler located on the 2015-2017 Mustang GT? Is it built in to the radiator? It is correct that the AT fluid cooler is built into the radiator, isn't it?
yohoeimmattbro
Amateur Mexican
Burlington, NC
Matthew
Oxford White 2017 GT
The factory ATF cooler is behind the radiator. If you look in the drivetrain section, mishimoto has done a great write up of this in their development of an enlarged 6r80 cooler
jasonstang
Denver, CO
2017 GB GT/CS 6MT
Oil cooler is by the oil filter which is basically a heat exchanger that has coolant routed though it.
ATF cooler is behind the radiator at the bottom.
Nothing is built into the radiator as far as I know. The radiator on the S550 is just a radiator.
gjpundsack
Scottsdale, AZ
Gary
Thanks guys. Those were the answers I was looking for.
Must_Tang
MA
Gone-2016 Mustang GT Premium
ATF cooler is sandwiched between he radiator and the condenser. Two bolts on one side, and it slides into mounting ears on the other. I know this becaus I've installed a Mishi radiator and oil cooler.
