Stock blow off valve released
Beaverton, OR
2015 MUSTANG ECOBOOST PREMIUM
:headbonk:This is a video of the stock blow off valve venting into the air rather than recirculating.
I'm not sure how to input the vid here's the link
dabsevo
Los Angeles
2015 Ecoboost Black
Is that your car? What tubing is he talking about when he said he removed it?
Beaverton, OR
Yes this is my car . There is a tube that goes from the BOV back into the intake, it recirculates the compressed air rather than releasing it. Doing this removes one side of the tubing from the BOV and leaves it open to vent out. You need to plug the other side of the tube. I used a welder to close a metal pipe and plug the hole. It sounds very clean.
Juben
Chattanooga, TN
Justin
2015 EcoBoost Mustang (AT) w/PP
How did you block off the port in the turbo intake pipe?
Sent from my Nexus 5 using Tapatalk
Beaverton, OR
You dont actually block the side thats closest to the turbo that is where the air is released into the atmosphere. The side that you remove needs to be plugged. I used metal piping and a welder to enclose it. Anything will work to plug it.
Nihil
Cowabunga
Roanoke, VA
Grey Goop
the JLT came with a cap, so I just left my bov hose unconnected and slapped the rubber cap on the port
Juben
Chattanooga, TN
Justin
I know. That's why I said the turbo intake pipe (TIP), lol. The intake pipe is where the recirculated air travels back to on a stock setup with the hose connected. When you pull the hose off, you leave the BPV alone and cover/plug the port in the TIP.
I don't have this problem because I have the JLT intake and it includes a cap for the TIP port. However, on a stock TIP, you'd need to cap it with something like one of those little furniture feet caps from Lowe's, duct tape, etc. Although I wouldn't recommend duct tape, I've known of people to use a variety of things to cap the port.
pduim
Huntington Beach
2016 Mustang GT PP
Thinking about doing this to mine.... is there no stuttering between shifts or anything? worried that an air sensor is gonna freak out when un accounted air is no longer there.
Slow89
Some place out west
11 sec bolt on ecoboost // 9.2 @ 151 2019 blower GTCS
Nope nothing at all you will be fine
