Enzo
Finally got some time to install this!
This review is interesting because this is my second time around getting this setup, from when I had it on my 2016 GT and now on my 2018 GT. I had about a year lapse in between the two cars with a different vehicle, so a lot of the experience on how it drove was slowly going away, until now.
Before adding these parts on, I had already installed the Steeda Pro Action Shocks, Billet Rear Shock Mounts, Progressive Springs, Front LCA and Bump Steer Kit.
One thing that annoyed me with the mustang when you pushed the car, it was the dreaded wheel hop and the skittish feeling the rear gives when under pressure. Making you question your ability to drive and also the cars abilities.
Now imagine this…
You’re sitting at the light and no one is around. It’s just you and the car… You slap it in first, light flashes green, you drop the clutch and… dun dun dun dun dun, car tries to go sideways a little on you, but you got this and correct it. Finally you're at the end of first gear, and you slap it in second, another dun dun dun wheel hop and a little sideways again, RPMs are at 6,000, and finally the rear decides to hold it down and you go to third gear and you're all good. Lucky for you, no one was around.
This whole scenario for me changed after installing the Steeda stop the hop kit.
It comes with the IRS subframe braces, IRS subframe bushing and alignment kit. I also installed the differential bushings with it as well. Install was not bad at all, very straight forward.
Now to the after effect of installing these parts. After the parts installed and settled in, I finally went out for a nice drive and pushed the car a bit, and to my surprise it wasn’t just take off improvements.
Same scenario, but different outcome. Light hits green, but this time, you get a little chirp and you feel it hook hard and the front of the car lifts up. Car pushes you off so hard and fast, you almost forget to shift, and the car hits redline, you shift it into second gear, tires chirp but the car is still shooting straight, RPMs are climbing even faster, you shift it into third, and right before it hits redline you let go of the gas… and your buddy in the passenger seat whispers “holy shit…” as if he saw a ghost, then with excitement says “man you can feel that hard in the stomach!” as he is getting giddy with excitement.
The stop the hop kit, does more than just stopping the hop, it actually keeps the car stabilized on hard launches, fast turns, or just going fast straight. You can really feel the difference especially when the tires want to let loose, it makes the car much more predictable and controllable. The rear always felt loose for me, because if you look at the bushings that the S550 comes with, rather it be the differential bushings or the subframe support bushings, they are very timid and soft. The whole reason why the rear does not give confidence. They are too soft for a car of this caliber. Steeda’s stop the hop kit really enhances the IRS subframe, and transforms the rear end of the car. You not only feel it hold the line straight when taking off hard, but makes taking fast turns better and allows you to go even faster. Another thing I noticed was cruising on the highway doing 70-80mph, going over bumps and different pavements, the car liked to stay straight. The rear stays put and follows the direction of the front wheels.
It also complimented the parts I had already on the car. Also for anyone having issues with wheel hop, or want to have better performance all around of the rear, I HIGHLY recommend this setup! I promise you won’t be disappointed. One tip of advice when installing them, is to loosen the rear front IRS bolts and bracket to help align the IRS Brace for easier install.
Thanks again Steeda for another great product!!
Now imagine this…
