Steeda stop hop - creaks pops
Steveclark79
Oregon
Stevd
18 mustang gt
I just had a steeda stop hop kit installed with vertical links and bmr diff support bushings. Car feels great but it creaks, pops, thuds. I don’t notice when I push on rear or even go over bumps. It’s starting to take off, stopping, slow speeds. Is this normal? I had a ford tech install them so pretty sure done right. He did them on jack stands. Does make that much difference if not torqued with load on?
JustSomeGuy
JustSomePlace
JustSomeGuy
Mustang GT
They don’t need to be torqued under load. I have all the stuff you mentioned with no noise to speak of. The braces are the most likely culprit if I had to guess, try loosening and retightening, then if that doesn’t work maybe a spritz if WD between the bracket and the mount points?
Caleb
North Carolina
Caleb
2022 Mach 1 Order; 2013 Genesis Coupe 2.0T R-Spec
No noise at all from my stop the hop kit, sounds like you might have some binding happening.
