Steeda Interior Hood Latch
tj@steeda
Timothy
Sorry for the confusion - we are asking about the thickness of the shaft that the latch goes on, on the Mustang.
We did not change the latch for export, that is why we are thinking the connection point on the Mustang may be a different size than what we run here in the States - going back to the question, why would they change the diameter on the Europen model.
Best Regards,
TJ
GR11M
GR11M
Herts, England
Graham
Ford Mustang GT
It sticks out 14mm and is 9 mm across
If that's not clear I can upload the pics when I get back from lunch
hinch
uk
Sideways
so based off what you're saying is the shaft is 9mm wide and the hole in the steeda item is 11mm
GR11M
GR11M
Herts, England
Graham
Ford Mustang GT
I hadn't actually compared the figures, but now you've pointed it out it does explain the movement in the vids.
TheOilman
CT
Jared
2017 SB GT Premium PP
So the hoodlatch is still on the left side of the car? Even though they moved the steering wheel to the wrong side(haha)?
Manders Mustang
The Boss
Birmingham - United Kingdom
2016 Race Red Ecoboost
They moved the bare minimum lol.
TheOilman
CT
Jared
So then if the part #'s match up for UK vs US it should be the same correct? On the US fordparts websote its #16916....hood control Cable Assembly. Not sure if that helps or you find a part #.
GR11M
GR11M
Herts, England
Graham
Ford Mustang GT
Not much I can do until Steeda get back to me.
tj@steeda
Timothy
I spoke to manufacturing & they investigated it ... the OE piece we looked at on the 2018 has as much play in it as your video.
We are not looking to revise at this time.
Best Regards,
TJ
Maoilearca
Hampshire UK
Mustang 2016 GT Auto Coupe (Guard). FP PP2
Best Regards,
TJ
Generally, and from customer feedback I’ve heard, it seems like Steeda products are sometimes hits and sometimes misses with people. You won’t know until you try. That’s why I’d never risk a purchase.
hinch
uk
Sideways
go buy some brass rod to create a bush that'll pad out the gap won't cost you much as you only need like 1cm of it at most.
GR11M
GR11M
Herts, England
Graham
Ford Mustang GT
I don't buy from Steeda very often but when i do...:(
GR11M
GR11M
Herts, England
Graham
Ford Mustang GT
I'm not bodging Steeda's bodge, I've already put the original one back on.
GT 550
Australia
Black GT MT S550
C'mon TJ, OE on these cars isn't a benchmark. Aftermarket is generally expected to be an improvement otherwise why bother?
If there's a good reason the play exists ie functionality, fair enough.
You guys can do better than this.
W111BOB
Doncaster, UK
Bob
Mustang GT 5.0 ORANGUSTANG
Best Regards,
TJ
I have to say that this is a "non-answer" IMHO-
surely Steeda want to be an improvement on the OE design? - which is why people buy from them...
isnt it?
to say that the original has as much play in it as theirs doesn't really give much confidence -
Or did I miss something? (at my age that is perfectly possible!!)
.... just my thoughts
