Steeda bump steer install questions
zrain25
Nh
Zachary
2019 f150 2021 mustang gt
I just installed the extended ball joints, since there is still 2ft of snow on the ground I ordered the bump steer kit as well. Is the goal to get the same angel as the lower control arm? I’ve been reading a few post and seems like most people end up with most spacers on the bottom.
Turbeau
Calgary, Alberta, Canada
2022 M1 HP 6SPD JFG
I set mine (with the car on it wheels) to the same angle (or as close as possible) to the lower control arms using an electronic angle gauge. No bump steer issues yet!
Make sure you have the tie rod ends evenly threaded into the collar to allow for full range of adjustment if needed.
zrain25
Nh
Zachary
That’s what I planned on doing but I also have the extended ball joints so I should have less angle. The electronic angel finder I thought of last night and ordered one
tj@steeda
Timothy
If you run into any concerns or questions - you can give us a call at 1800 950 0774 & Jamie/our Tech Team can help support/evaluate.
Have a great night!
Best Regards,
TJ
zrain25
Nh
Zachary
Just finished install ended up with more spacers on the bottom. Used a jack to lift the front suspension until if it was off the jack stands. The lower control arm with the steeda extended ball joint I had 6.5 degree angle. Closets I could get the steering angle was 6.7 should be ok. We will see after alignment.
