DAVECS1
I have a 2017 Base PP car. I have the 19 inch 6GR wheels with Michelin Pilot Sport Tires. 305 in the back and 285 in the front.
I have Stance Coil Overs
The diff and body mount bushings in the rear are Delrin
Running GT350 Half Shafts
Boomba Vertical Links
Steeda LCA bearings
Both Axle nuts are Red Locktite at 150 ft lbs
It does not matter if i am going slow or fast, but If I make a turn to the left that is 90 degrees or more i am getting a pretty prominent squealing sound. I tried Applying the brakes, but trying to find a place to maintain some speed while applying the brakes and turning 90 degrees or better is harder than you think. Applying the brakes when I could did not seem to make the noise any better.
MY thought is a rear hub assembly. Those seem to be less than stellar according to other S550 owners. My car only has 2100 miles on it, but that does not mean much. It has seen strip duty and two road courses.
Just wondering if anyone else has had a similar noise, and had any ideas.
I am contemplating buying the MOOG replacement hubs.
Steeda LCA bearings
