Squeaking front end, over bumps. Very faint.
Metz3020827
Arizona
Connor
2017 Mustang GT
Hey guys. I have 2017 Mustang GT and have been experiencing a little squeak in the front end for a month or so now. I tried recording it but it’s hard to hear.. it doesn’t make a clunk just a squeaking noise it’s so strange.
It happens over bad roads otherwise it’s silent on flat roads.
I’m on fortune auto coilovers, have steeda extended ball joints and steeda’s bump steer kit.
The only thing not replaced is the upper ball joint.
It’s driving me nuts. I’ve also been experiencing vibration in the foot well/gas pedal very very slight. Possible engine mounts? I don’t see anything leaking. So not sure.
BigD94
New Jersey
Dom
2016 GT
Last year I had an absolutely terrible squeak/creak in the rear suspension when going over speed bumps. I checked the sway bar bushings and they were dry af. Zero grease left.
I ended up ordering new sway bar bushings and greasing them heavily. The squeak was gone immediately after.
You might be having the same issue on your front sway bar.
Metz3020827
Metz3020827
Arizona
Connor
2017 Mustang GT
It does sound like it’s in the middle of the car somewhere can’t narrow down the side it’s on.. you might be onto something. I wonder how hard they are to replace
S550HPP
PDC
2022 HPP Vert
Coil over spring seats or sway bar bushings are a good start.
Metz3020827
Metz3020827
Arizona
Connor
2017 Mustang GT
Spring seats?
and I should try the swaybar bushings…. They’re inexpensive I’m not sure how hard they are to replace though
S550HPP
PDC
2022 HPP Vert
Surfaces coil spring ends make contact with. Could be the dampers as well...any leaking?
Metz3020827
Metz3020827
Arizona
Connor
2017 Mustang GT
No sir, no leaking. And no unusual bouncing or anything either:
S550HPP
PDC
2022 HPP Vert
Ford sway bar or aftermarket w poly bushings ? Grease zurk?
Metz3020827
Metz3020827
Arizona
Connor
2017 Mustang GT
Just stock as far as I know. It’s a performance pack car so if that gets an upgraded swaybar, that I guess lol.
It’s just a black swaybar. Looks stock to me
S550HPP
PDC
2022 HPP Vert
Have the spring sleeves?
Metz3020827
Metz3020827
Arizona
Connor
2017 Mustang GT
Spring sleeves?
Sorry haha I’m unsure of the terms you’re using. I bought the car with modded suspension so I’m learning all this stuff
S550HPP
PDC
2022 HPP Vert
Go to fortune auto they have them there. They are sleeves that go over spring to eliminate noise.
gtppmt
New Jersey
2016 Mustang GT PP M/T
Did you figure out the source? I heard PP mustangs have bonded front sway bar bushings.
Metz3020827
Metz3020827
Arizona
Connor
2017 Mustang GT
They do indeed. Apparently it’s the HEIM joints (my bumpsteer kit)
