Square setup with stock PP GT wheels
neodark
Left 4cyl @home
Jorge
2019 GT PP2
As a cheaper alternative, can you run a square setup in the stock GT PP wheels? I believe front is 9in with 255s and the rear 9.5 with 275s.
I don't think it would make sense to rotate the wider wheels to the front, even with the same tire size... But, buying 4 tires the same size is normally a better price.
dwaleke
Jeep
A square setup usually implies same wheel/tire combo all the way around.
You can run 255 or 275 wide tires on the PP wheels however the rear wheels will not fit on the front without a spacer.
El_Coyote
California
fonz
s550 coyote, 3 peddles, big brakes and rec seats
just a fyi. the front half inch shy wheel is gonna make the tire have an hourglass shape do to the extra 20mm thicker tire. the rears will still retain the round look. so your tires are gonna look kinda stupid imo, stick with stock size, or beef up front and rear accordingly, if you don't want them to look funny. Had an old customer with a corvette that was ignorant as shit, and wanted to go your route, he had staggered wheels, and it looked really stupid. but it was his car and his money. unless your going to run an extra set of rear wheels upfront, and discard the fronts, but then youll have to run said spacer.
gl
