Spring install and bolt replacement
Budnr22
Northern VA
2016 GT350 - Oxford - Tech Pack
For the folks who have installed springs on your ride, did you follow Ford guidelines and install new bolts where specified?
I tend to be "by the book" to a fault sometimes. I am about to order all new bolts from ford, but thought I would check with the team here.
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
I did not. Most did not. I get the suspicion you will lol.
But honestly there is no reason you "have" to. They have to be knocked out and I think they assume someone will ruin the threads but if you do it right you will not hurt the threads.
Twenty15
Fort Collins, CO
Paul
2015 GT Premium | DIB
I did not
Budnr22
Northern VA
Thank you very much. I am on the fence with this.
Todd15Fastback
Atlanta, GA
Todd
2015 Mustang GT PP Fastback
I had a whole slew of suspension parts installed by Steeda. For the spring install they did not use new bolts. Honestly, I have not seen anyone install new bolts with spring installations unless the bolt was stripped or broken.
Budnr22
Northern VA
Thank you. I was reacting the below. I am such a pain. I create more work for myself. I am horrible to work with.
:frusty:
yellowstangatl
Minnesota
2024 Dark Horse Premium
I didn't. I had a ford tech do it and he never mentioned the need to.
Budnr22
Northern VA
Thanks again.
just ordered my spring compressor.
soon as that arrives, I think I am ready.
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
Thanks again.
How much will that set you back ?
Anthony 05 GT
Northern Harford County Maryland
2005 Mustang GT, 2015 Mustang GT Premium
The bolts are one time use for one reason...they are ''torque to yield'' bolts which means they are torqued to the point where they begin to want to stretch and are close (supposedly) to their overload point.
I re-used mine on my '05 and never had a problem. One rear control arm had a torque spec of 125 ft lb and I just torqued them to about 120 with a little red loctite.
