Sportline Alignment
RHDZach
Mertztown PA
Zach
2015 Mustang GT Premium - Performance Package
Hey guys, so far i have a couple basic bolt ons on my '15 GT Premium with the PP. I want to lower the car, and i'm considering the Eibach Sportline springs. The car isn't a daily driver, so i'd like the extra drop over the pro-kit. I've tried to do some research on here regarding the alignment. I've read that the sportline kit will only effect the camber by -.04 which isn't terrible, and it does not require camber plates. I saw a post from a member on here that said his camber was about -2.5* after installing his springs. I don't want to sacrifice my tire's life span just to have the car a little lower.
So basically my question is, for anyone that is running sportline springs, how close were you to reaching factory alignment specs? If you were far from factory spec and made any additional modifications to improve this, what did you do?
Thanks a lot in advance!
-Zach
Niz55
Us
17 GT350
Ride Height Difference
Front: Approx 1.5"
Rear: Approx 1.3"
Spring Rates
Front - 217 lbs
Rear - 879 lbs
Front Specs
OE rate: 28 N/mm (160 lbs/in)
SPORTLINE progressive rate: 38 - 58 N/mm (217 - 331 lbs/in)
Bump-stop: New Eibach bump-stop
Damper: OE
Tubing: Yes
OE wheel center to fender: 396 mm (15.6 in)
SPORTLINE wheel center to fender: 357 mm (14.1 in)
SPORTLINE can be aligned to OE Specs: Yes
Front Alignment:
OE Camber = -0.8 deg (+/-0.8 deg)
OE Caster = 7.2 deg (+/-0.8 deg)
OE Toe = 0.00 deg (+/-0.2 deg)
SPORTLINE Camber = -1.2 deg
SPORTLINE Caster = 7.5 deg
SPORTLINE Toe = 0.2 deg
Approximate installation time: 2 hr
Rear Specs
OE rate: 117 N/mm (668 lbs/in)
SPORTLINE progressive rate: 154 - 174 N/mm (879 - 994 lbs/in)
Damper: OE
Tubing: Yes
OE wheel center to fender: 387 mm (15.2 in)
SPORTLINE wheel center to fender: 353 mm (13.9 in)
SPORTLINE can be aligned to OE specs: Yes
Rear Alignment:
OE Camber = -1.2 (+/-0.8 deg)
OE Toe = 0.1 deg. (+/-0.2 deg)
SPORTLINE Camber = -1.6 deg
Niz55
Us
17 GT350
Is been around 3000 miles since I installed my springs. I have not gotten alignment yet because I am waiting for some struts and shocks to come out. Even without alignment my car drives pretty damn good.
