dbasql
http://djdenverb.com
Hello,
2016 Roush RS3 Phase 2 Supercharged, located in Tampa Florida
All Engine work and custom tune by Ken Palm Beach Dyno (RareFab)
It will accept E85 but other than Dyno testing I haven't used E85 because its not available near me and it has plenty of power using 93 octane!
Getting set to move on to a new project. Figured I would try here 1st to see if a Mustang enthusiast wants the car.
Black Exterior and Interior (with baseball threads)
Right at 25k Miles
Car is manual
Brand New BAER rotors and new brake pads
Carbon fiber steering wheel.
Always kept in garage
Everything works on the car and it has a new battery.
Seats in good shape, back seats never been used.
The Candy Apple Red Project 6GR wheels are currently on the car.
Clear Bra installed on front
Tires have about 5k left on them. Car will come with Project 6GR wheels, original Roush wheels and tires and an extra set of staggered tires.
The car has just about every Steeda handling improvement product installed. If you are looking for a Cadillac ride this is not the car. If you want something that handles like a mofo this is it.
Oil changed every 3k with Royal Purple.
I am listing most of the mods.
Roush has this valued mid 40s, I will sell for $39k. This is a lot of car for 40 grand, it has been babied and tastefully modded. I get more looks/comments on this car compared to any other previous project.
I will get a full detail for buyer prior to pickup.
If you have any questions please send DM. I hope this goes to a community member.
TY!
Exhaust
ROUSH Quad Tip Active Exhaust Kit
Active Exhaust Link
Wheels / Tires
Front - PROJECT 6GR 20X10 5X114.3 35MM Brushed Candy Apple Red
285/35ZR20 Toyo R888R
Rear - PROJECT 6GR 20X11 5X114.3 35MM Brushed Candy Apple Red
305/35ZR20 Toyo R888R
6GR Link
Engine / Drive Train
ROUSH/Ford Performance TVS R2300
Roush TVS Blower Link
K2-TVSP6-2625 K2 2.625" Pulley for 2.3L TVS
Pulley Link
FORE-FS STAGE 3 Fore Innovations L4 Return Fuel System with Fuel Rails and ID1050x Injectors
Fore L4 Fuel System Link
TSS Oil Pump Gears
TSS Timing Sprocket
TSS OPG Link
WHIP-T68E BILLET TWIN 68MM BORE ELECTRONIC THROTTLE BODY for ROUSH, TVS
Throttle Body Link
K2-TVS AIR FILTER K2 ULTRAFLOW High Performance Air Filter for Roush/VMP Cold Air Kit
Air Filter Link
McLeod RXT 1000HP Clutch
McLeod Clutch Link
McLeod Racing Aluminum Flywheel
Mcleod Racing Flywheel Link
Steeda Braided Clutch Fluid Line
Steeda Braided Clutch Line Link
MGW Race Spec Short Throw Shifter
MGW Shifter Link
BG Products Syncro Shift II Synthetic Gear Oil
Gear Oil Link
Braking
Brembo 6 Piston / Hawk Racing DCT-70
Stainless Braided Brake Lines
Brembo Brake Kit Link
Brake Pads Link
Brake Lines Link
Castrol SRF Fluid
Castrol SRF Link
Engine Bay
Moroso Aluminum Fuse Box Cover
Moroso Cover Link
Mishimoto Coolant Tank
Mishimoto Coolant Tank Link
Reisch 170 T-Stat
Reische Thermostat Link
Steeda Hood Struts
Steeda Strut Link
Suspension
Roush Adjustable Coilovers
Roush Coilover Kit 3 Way Link
Steeda
IRS Subframe Bushing Support System
IRS Subframe Alignment Kit
Billet Aluminum Vertical Links
IRS Subframe Support Braces
Adjustable Rear Toe Links
Steeda STH Kit Link
Steeda Mustang Differential Bushing Insert (Aluminum)
Differntial Bushing Link
Steeda Rear Lower Control Arm Bearings
Steeda Lower Arm Bearings
Steeda Front Camber Plates
Steeda Camber Plates Link
Steeda Front and Rear Sway Bars
Steeda Sway Bar Link
Steeda Billet Front and Rear Sway Bar Mounts
Steeda Sway Bar Mounts Link
Steeda Extreme Gtrac K Member Brace
Steeda Gtrac Link
Lighting
Diode Dynamics Interior LED Conversion Kit
Diode Conversion Link
Exterior
Complete Roush Rs3 Body Kit
Roush Body Kit Link
Interior
Roush Shifter Knob
Shifter Knob Link
Roush Pedal Kit
Pedal Kit Link
Right at 25k Miles
Car is manual
TY!
Exhaust
Active Exhaust Link
Wheels / Tires
6GR Link
Pulley Link
TSS Oil Pump Gears
TSS Timing Sprocket
TSS OPG Link
Throttle Body Link
Air Filter Link
McLeod Clutch Link
MGW Shifter Link
Gear Oil Link
Braking
Brake Pads Link
Brake Lines Link
Castrol SRF Fluid
Castrol SRF Link
Engine Bay
Moroso Cover Link
Reisch 170 T-Stat
Steeda Hood Struts
Steeda Strut Link
Suspension
Steeda
Steeda STH Kit Link
Steeda Gtrac Link
Lighting
Exterior
Roush Body Kit Link
Interior
Roush Shifter Knob
Shifter Knob Link
Roush Pedal Kit
Pedal Kit Link
