So when does the variable valve timing change?
mauleed
Cherry Hill, NJ
2015 Convertible GT
My understanding is that the valve timing has two settings. What RPM do they switch at?
jasonstang
Denver, CO
2017 GB GT/CS 6MT
They are constantly moving given fuel type too.
Anthony 05 GT
Northern Harford County Maryland
2005 Mustang GT, 2015 Mustang GT Premium
That's right, each camshaft is independently adjusting in relation to the crankshaft to optimize torque and hp. The knock sensors play a large part in this. Oil and spring pressure are what change the timing through the phasers in the front of the heads.
mauleed
mauleed
Cherry Hill, NJ
2015 Convertible GT
So only the timing changes? I thought I had read something about how the lift changed as well, but only in one stage. I guess that's where I was confused. I must have been reading about a different engine.
kris5597
Baton Rouge, LA
2018 Mustang GT A10
Lift and duration do not ever change, that is not variable. What is variable is valve overlap, intake valve opening position, and exhaust valve closing position.
Anthony 05 GT
That's right, as the cam rotates the valves will always lift and close the same way, only they can vary in timing in relation to the crankshaft (piston timing) and each cam can vary in timing to each other. Keep in mind, there are 2 cams in each head...one for intake valves and one for exhaust valves and they adjust in relation to each other to optimize power in a given situation such as rpm, fuel quality and temperature.
ScottsGT
Lake Wateree, SC
Scott
2015 GT, DIB
