chohan
- Jan 14, 2019
- NC Foothills
- Erik
- '19 GT, 301a, 10r80
Ok I have a 2019 GT base 301a.
When changing oil, there is no trap door but there is a smaller vented belly pan that slides in behind the main undercover/belly pan.
It is held up by four 7mm bolts that are removed and then I have access to the oil filter. Those 7mm bolts screw up into small threaded metal clips, one of which is so loose, it barely stays clipped in the hole.
Anyone know the part # of those threaded metal push clips?
When looking at the parts diagram, I don't even see that smaller vented belly pan(?) listed.
I only see the main belly pan which I think is called an Under cover (JR3Z-17626-A). I do see something with vents called an Insulator listed, but it looks a bit different than mine and says for convertible.
Any help is much appreciated.
