Sold: GT Sleeved Gen II forged short block + Gen II heads and parts.
whatsup62
Jupiter
EDIT w UPDATE - Sweetening the pot a little. Adding pics and additional parts.
Gen 2 heads - mild bowl blending with PAC1234 springs. Brand new stock cams, lifters, followers, MMR cam cap hardware ,Cometic gaskets, Boundary OPGs and TS.
$10,500.00 for everything (short block, heads, all parts mentioned and shown).
Does not include shipping or fees of any kind.
Will not sell heads or parts separately UNLESS short block sells by itself.
Freshly assembled gen 2 sleeved short block with all the goodies.
No expense spared on this build. All brand new components except block and crank.
Plans were to throw A LOT of boost at it. Short block should be good for 1500+
2016 Gen 2 Block, deburred with Darton sleeves Std bore assembled with the following:
Boss crank balanced to rotating assembly – dual keyway added
Molnar Power adder rods with 7/16" ARP 2000 Rod Bolts.
Diamond MOD2k pistons – std deck and cc heads – 11.8 to 1 CR
Total Seal piston rings w/Napier 2nd ring. Ring gap .028-.029 for big boost.
Clevite rod and mains, std size.
MMR oil squirter block-offs.
ARP main studs and side bolts.
Included but not assembled:
MMR billet rear main seal cover, fasteners and seal.
MMR oil pump pickup (larger opening) with standoff hex nut, new stock pickup included.
MMR head cooling mod kit.
Oil filter mounting adapter (stock one from motor).
New FOMOCO oil pan, oil pan gasket (windage tray) and new fasteners.
Innovators West Inc. harmonic balancer with ARP balancer bolt and washer.
ARP 11mm head studs, washers and nuts.
All machine work done by professional machine shop with state-of-the-art CNC.
Royal Purple assembly lube used on bearings and lube points.
Extreme Pressure Lube #3 used on pins, rod bolts, studs.
Asking $8750.00 Can be picked up in Iowa, shipping extra.
olaosunt
Indiana
Very nice !
What’s the new direction?
olaosunt
Indiana
