Shock mount bolt not flush
jabrax
Montgomery County PA
Jeff
2015 ruby red PP GT
I have been getting this annoying knock from my back driverside. Recently, I realized i could get a fingernail between the upper right shock bolt and the wall. It was torqued to speck, so I asked a local shop to hit it with air for me. Drove off, and no knocks until near home. Pulled the wheel and the small space is still there, hard to see just looking at it straight on, but it failed my flush fingernail test lol.
I have been checking everything, toe rods, vertical links, sway bar bolts. Annoying as hell
Could this very tiny gap cause the shock to knock? The gap appears to be more prominent on one side of the bolt.
jbailer
Joe
When installing the upper shock bolts, compress the shock some by hand so the shock mount isn't pressing up against the little stops. That way you make sure it is sitting flush. You definitely don't need an air gun, those should only be torqued to 66 lb ft.
Niz55
Us
17 GT350
:thumbsup:
