Sold: California Schroth QuickFit Harness; Red (05-17 All)
VooDoo387R
Cali
2017 GT350R & 2020 GT500
  • 4 Point Removable Harness
  • Ideal for Track and Street Use
  • Compatible with a HANS Device
  • ASM - Anti SubMarining Technology
  • Works with Factory Seat Belt Receptacles
  • 2" Wide Black Polyester Webbing
  • Fits All 2005-2017 Mustangs
Four Point Removable Harness. A Schroth Quick Fit Pro Four Point Removable Harness is the perfect solution for Mustangs that pull double duty on the street and at the track. The Quick Fit Pro will keep you securely behind the wheel of your Pony while you're carving corners at the track. Then it can be easily removed giving you full access to your interior for people or cargo on the street.
HANS Device Compatible Schroth's Quick Fit Pro is the world's first 4 point harness that was designed to be used in conjunction with a HANS (Head and Neck Support) Device and your factory seats. Traditional 4 point restraints do not join at a center point, they are sewn to the lap belt leaving almost a 6" to 8" separation between them. The Quick Fit Pro is designed in such a way that both shoulder belts angle in towards the Cam Lock easily facilitating the use a HANS Device.
ASM Technology. The Schroth Quick Fit Pro features Anti-Submarining (ASM) Technology that positions the lap belt low across the pelvis. This keeps your hips and back side firmly planted in the seat preventing you from sliding under the lap belt in the event of a collision.
Works with Factory Safety Restraint System. The Schroth Quick Fit Pro works with your Mustangs existing factory seats and safety restraint system allowing for easily installation and removal. The Quick Fit Pro clicks into the car's female seat belt receptacles and anchors to the factory points which are load tested to withstand a 3,000-pound force for 6 seconds. By using the stock seat belt receptacles the vehicle is aware that a person is seated and restrained, silencing the warning chime as well as taking full advantage of the factory seat belt pre-tensioner.
Polyester Webbing. Schroth's Harness Belts are made from 2" wide polyester webbing. Engineered with “memory effect” Schroth's polyester webbing features special mono filaments laterally woven in, that perform like small leaf springs to keep the webbing flat. This results in better load spreading over the full width of the webbing. Polyester webbing also has a better force/elongation ratio, when compared to standard Polyamide (NYLON®) webbing, so it can convert more energy during an accident.
Application. This Schroth QuickFit Pro 4-Point Harness is designed to fit all 2005 to 2017 Mustangs with the factory seats and safety restraint system. Including the V6, EcoBoost, GT, Bullitt, BOSS, Shelby GT500 and Shelby GT350 models. Available individually or as a set of two. Please select from the options listed above.
Fitment: 2005 2006 2007 2008 2009 2010 2011 2012 2013 2014 2015 2016 2017
Price: $300 shipped to the lower 48 (NEW NEVER USED)
KevMeanRedGT
Tennessee
Kevin
2016 Mustang GT Performance Pack
PM sent I'll take them
VooDoo387R
Cali
I replied
