Ridetech Coilover Kit Level 2 HQ Series 2015-2016
Status
Not open for further replies.
CJ Pony Parts
Harrisburg, PA
www.cjponyparts.com
A large variety of Mustangs across all generations
Ridetech Level 2 HQ Series Coilover Kit for all 2015-2016 Mustangs.
[ame="[MEDIA=youtube]kIWudwMT2Cc[/MEDIA]"]
NOW IN STOCK!!!
The chance to make your 2015-2016 Mustang handle like it is on rails while still keeping a comfortable and adjustable ride is now possible with the help of the Level 2 HQ Series Coilover Kit (P/N: 12270210) from Ridetech!
This Ridetech Level 2 HQ Series Coilover Kit is designed to fit all 2015-2016 Mustangs regardless of options or trim levels. Once installed, the transformation from your factory or current aftermarket suspension setup will have you thoroughly impressed. Featuring the ability to perfectly dial in your ride height, caster and camber settings is only the beginning. You will also have 26 possible adjustment points when attempting to dial in rebound. All of this, combined with a rugged and innovative design, will give your S550 Mustang the ability to confidently tackle just about any corner without sacrificing ride quality.
Features and Benefits:
- Anodized Finish Protects Against Corrosion
- High Tensile Premium Steel CNC Cold Wound Coil Springs
- Double Sealed Rod Guide with Dust Cover Eliminates Oil Leakage
- Unique Pinch Clamp Height Adjuster Uses Finer Thread for Easy Adjustment
- Monotube Gas Pressure Design Offers Superior Fade Free Performance
- Large 1.834" Piston Provides Outstanding Ride Quality
- Kevlar Lined Bearings for Noise Free Operation
- Upper Strut Mount Offers Caster Adjustment
- Lower Strut Mounts Offers Camber Adjustment
- CNC Machined Billet Hardware
- Rebound Single Adjustable
- 5/8" Chrome Shock Shaft
Included in Kit:
- (2) Steel Mono-Tube Coilover Struts
- (2) Aluminum Mono-Tube Coilover Shocks
- (4) HyperCo 2-1/2” Coilover Springs with Proper Spring Rate
- Performance Engineered Mounting Brackets
- Rear Sway Bar Relocator Kit
- Drill Bit and Riv-Nut Installation Tools
- All Necessary Hardware for Installation
- Spanner Wrench
- Detailed Installation Instructions
Please Note: This kit is designed and engineered to offer you the best performance while providing a 1-3/4” to 2” drop when compared to the stock ride height. Although this kit can be adjusted to lower the vehicle up to approximately 3”, you will end up being outside the range of caster and camber adjustment as well as limited by the size wheel and tire combinations that you choose to go with.
*This kit will require you to drill two holes (drill bit included) on the driver and passenger side and install the included Riv-Nuts. This is the only modification that will need to be made to complete installation.
Manufacturer Part Number: 12270210
Taking an old-school muscle car and enhancing its performance is one thing, but taking a late-model muscle car to the next level of performance is another. This kit does just that by letting you tune your suspension with the simple rebound adjustment. We are pleased to offer you the ultimate in ride quality and handling performance with these new Ridetech Level 2 HQ Series Coil-Overs. The design and engineering behind this kit will offer you the consistency and compliance that the new Mustang platform deserves.
Order the Ridetech Level 2 HQ Series Coilover Kit for your 2015-2016 Mustang from CJ Pony Parts today!
CJ Pony Parts
CJ Pony Parts
Harrisburg, PA
www.cjponyparts.com
Status
