Reverse lockout sticking
W111BOB
Doncaster, UK
Bob
Mustang GT 5.0 ORANGUSTANG
I am experiencing a strange phenomenon on my manual MY17 GT
The reverse lockout is sticking "up" when I come back out of reverse gear
It will push down again (manually) - but its a little worrying
I have removed the gear knob and squirted a little wd40 on the shaft - and it frees it up a little
any ideas?
thanks
Bob
W111BOB
W111BOB
Doncaster, UK
Bob
Doesn't removing it involve 'un-gluing'it?
Supersolo
Northamptonshire
2019 Ford Mustang GT
After viewing the CJP youtube video, evidently not.
Remove gator & collar assy as is. Which appears to provide access to the shaft and lower collar.
I think you'd only disassemble the collar if you were replacing the gator or the collar itself.
W111BOB
W111BOB
Doncaster, UK
Bob
hey thanks for that - at work and restricted internet access (no youtube allowed etc)
appreciated!
Ill have ago
W111BOB
W111BOB
Doncaster, UK
Bob
anyone else experienced this?
I believe that Steeda do a replacement?
is it for just this reason?
all assistance gratefully received!
Bob
Benno2000
Essex
Ben
2017 GT - TripleYellow \ Black stripes
Bob
Hiya Bob
I’ve not had your issue but just switched mine over to the Steeda one when I was replacing my gaiter. IIRC the Steeda one is a single billet piece rather than the split plastic (ie breakable) OEM one - looks good too lol. Supplied by KentMustang.
Benno
W111BOB
W111BOB
Doncaster, UK
Bob
Ben - how long did it take to swap out for the Steeda one?
is it simple?
(the video above makes it look easy - but we all know that sometimes theses things require a degree in astro- physics to do!:giggle:
Benno2000
Essex
Ben
is it simple?
Hiya Bob,
Say 30min?
Whilst it is easy in terms of difficulty, there are a few tricky bits - removal of gear stick trim requires force which is unnerving as does splitting the original lock-out. Tbh, I rate my competence as relatively low and I managed it :giggle:
This guy highlights the tricky bits but he does make a mistake with the o-ring at the end.
Benno
Manders Mustang
The Boss
Birmingham - United Kingdom
2016 Race Red Ecoboost
All i'd have said, it try rotate the knob anti clockwise a few degrees!
W111BOB
W111BOB
Doncaster, UK
Bob
Well I guess you would Steve
Never mind
:clap:
Manders Mustang
The Boss
Never mind
:clap:
Haha, i had the same issue with my 350 knob, and then with my oem knob, turns out it was literally 1/100th of a turn off centre and the lockout collar was catching on the inside of the knob and stopping it from dropping back down (without pinging it down)
W111BOB
W111BOB
Doncaster, UK
Bob
Obviously I had removed the gear knob completely... as I mentioned in the first post.
It was still sticking
I guess you didnt read that bit....:giggle:
Manders Mustang
The Boss
I read it, my point was that, regardless on how much you put it on, remove it, repeat, if you twist it too tight it can catch inside the knob.
W111BOB
W111BOB
Doncaster, UK
Bob
Steve - I realise today is your birthday ...:party::party::party:
but
IF I had removed the gear knob ...
HOW could the remote lockout be sticking / catching on the gear knob?
it wasnt attached!!!
