imrex613
- Mar 28, 2019
- Lorton, VA
- Brian
- 2015 Mustang GT
Just had a quick question for the turbo guys running boost off wastegate. How much boost are you actually seeing vs your spring? Right now I have a 6 psi spring but I see 5.58 max boost in my logs. I know it's a 6 psi spring and that's what it "should" make but in every other turbo car I've built normally the car makes more than the spring (IE 6 psi spring making 6.5-7.5). I do have a boost controller and can easy adjust it up higher but im just curious what others are seeing. I am running turbo guards instead of air filters and thought about pulling them to see if anything changes but im afraid of sucking debri in there. Thanks in advance!
