Sold: Arizona ProMeth Direct Port Methanol Injection
Bull Run
AZ
2015 Mustang EB Prem PP
Updated version of the setup in the link below that includes two additional check valves (three total for better fluid control) and the fifth nozzle option (you can add a nozzle in your charge pipe so the MAP sensor can "see" the temp drop). This also includes the intake manifold so you don't have to worry about messing up your original one, and two extra sets of nozzles so you can change the injection volume as needed.
I no longer need it as I found an E85 station nearby and switched to the upgraded HPFP and injectors setup. $250 shipped/obo.
https://prometh.com/products/ford-mustang-ecoboost-direct-port?variant=44075562190
I also have a WMI pump mount that places the pump right by the windshield washer fluid reservoir, $30 shipped/obo. If you get this, I'll throw in the windshield washer fluid reservoir with nylon tubing connector on the bottom for the cost of shipping.
https://www.nitrousexpress.com/water-methanol-pump-mount-for-15-up-mustang.asp
S550chip
Wildomar
Joey
2018 Ecoboost mustang
Still available? How many miles put on this setup and how many ccs are the injectors?
S550chip
Wildomar
Joey
how did it perform? Do you suffer from siphoning with This setup?
Bull Run
Bull Run
AZ
It performed well and in theory, the ported setup should been better due to smaller nozzle sizes and even distribution. I couldn't tell the difference power wise (unfortunately, I didn't do another dyno run after this) but I the fluid usage went down as I wasn't injecting as much.
