PP2 Registry
maddseason
englewood, fl
2020 mustang PP2
I m wanting information on the possibility of installing Mach 1 front wheel lip molding. any info is appreciated or anyone having a set they don t want.
I installed and they don’t fit without creating some way to mount in lower front fender. They don’t tie into the side skirt either. It looks half assed so I took the $300 part off my car.
cerbomark
TN
20 GT PP2. 21 Mach1 (Sold)
Thanks, that s what I was afraid of and didn t want to blow 300 either. Now if someone gave me a pair I d try like you did but most likely be a fail.
TonyNJ
Northern NJ
www.instagram.com
Tony
Is this a different Marti than the one you shared previously?
So the important #'s are that there were only 39 Rapid Red PP2s made. 👍
maddseason
englewood, fl
2020 mustang PP2
There are a few reports the one I bought I guess is more about my cars production. There is a pricier version if I remember correctly. But these production numbers are more detailed than what I got
maddseason
englewood, fl
2020 mustang PP2
Just wanted to send a friendly message to correct the interior color statement. The red interior is “rapid red”. The exterior red color is race red. And if anyone knows where I can get a set of rapid red recaro sea
I stand corrected on the color. I checked my window sticker the color is called “showstopper” red.
cerbomark
TN
Original report I showed you before.
cerbomark
TN
Please forgive my questions if they ve been discussed ready but I couldn't find one source , even outside the forum, on ALL the PP2 differences. I m new to the pp2 but not new to Mustang. I Hear but can t confirm, K frame brace (more than a GT), other frame bracing I can t confirm under the car, larger sway bars and stiffer springs, Lower ride height, some sort of brake duct cooling, larger radiator, different magnaride settings, I m aware of the wheels, not certain about brake size comparisons (to mustangs) and I may be forgetting more. The engine I assume a standard 5.0 Mustang( don t think there s any different tuning)? Not sure what s true and not sure how the upgrades differs from a GT, GT350 or Mach 1. I ve looked thru dozens of u tube reviews also only to find limited mechanical information. Thanks!
TonyNJ
Northern NJ
www.instagram.com
Tony
Did you read these...
https://www.cjponyparts.com/resourc...Ujm-FnC7ckIB0JGi-flbU5Y4LH5meDGcuS3v6Y5GyNyii
https://www.steeda.com/mach-1-vs-gt...0G41WH_5P2x_pF4YX-wjoLjx5QC6vJJkaArVaEALw_wcB
cerbomark
TN
maddseason
englewood, fl
2020 mustang PP2
The PP2 has a unique rear decklid spoiler. Only available on the PP2. That was my first modification.
Silver Bullitt
Parkville, MO
2018 GT Coupe PP2
Thanks, that s about everything I mentioned. Torque is interesting as they are all within 9 ft lbs of each other with the GT350 ahead and the pp2 and M1 equal.
Interesting they don’t have the wheel specs correct on the PP2 in the CJ article. It shows 19x9.5 (f) and 19x10 (r). They are actually 19x10.5 (f) and 19x11 (r).
