PO61B Code Thrown
brandon_5.0h
Charlotte, NC
Brandon
2019 Mustang GT
I have been having this code thrown multiple times after a cat-less header install. I’ve taped up and zip tied the rear 02 sensors out of the way. I extended the passenger side harness to reach and spliced the driver side. My thought was to get the rear 02’s to read oxygen instead of being welded back into the pipe, as Lund will not turn them off. Under any load, the car will throw the code and put it into limp mode, expressing that the throttle actuator sensor is messed up instead of a specific 02 code. I checked in the diagnostics section on my nGuage, even checked with Lund to clarify, and the 02 / fuel category is marked red. Any help or advice would be greatly appreciated. AFR seemed cut back, has mileage seemed drawn back, and there is a slight miss under decent acceleration.
lacanteen
Louisiana: Cajun Country
George
From one source:
Error Code P061B is defined as Internal Control Module Torque Calculation Performance.
This error code is a manufacturer-specific trouble code, meaning it does not apply to all vehicles makes. Rather, it applies only to specific vehicle makes, such as Ford. Specification on the definition, troubleshooting, and repairs still vary from one make and model to another.
Definition
The PCM (powertrain control module, also known as ECM or engine control module) compares the actual torque signal computed from the air flow sensor signal with the torque signal demanded by the driver, which is computed from the accelerator pedal position sensor signal. If the PCM determines the computed values are out of factory specifications for the vehicle, then it will set the Error Code P061B, indicating a fault in the internal control module torque calculation performance.
Common Symptoms
As with other error codes, this code activates the Check Engine light and registers the code to the vehicle’s memory system.
Possible Causes
There are many possible causes for this code, such as:
  • Defective throttle valve control servo
  • Open or shorted harness in throttle valve control servo
  • Poor electrical circuit in throttle valve control servo
  • Defective MAF (Mass Airflow) sensor
  • Foreign matter inside airflow sensor
  • Software incapability problem
  • Defective PCM (rare)
How to Check
Technicians check the air cleaner to the engine thoroughly and make sure the cleaner cover is on properly.
When checking the air filter, technicians don’t just make sure the filter is clean or not, they also make sure it’s sitting properly flat on its place. There should be no tearing on the foam or in the pleats, or neoprene type seal. Cheap air filters will collapse easily, which can also cause this code, as unfiltered air can get past it, messing up the MAF sensor.
Bad air filter also causes a vortex to the air inside the filter, causing erratic readings in the MAF sensor, causing the throttle body to shut down.
How to Fix
Error Code P061B is an air filter or intake snorkel issue. Thus, replacing the air filter can usually solve the trouble code. Of course, it is important to get the right quality and size for the filter.
Also, shorted harness and poor electrical circuit in the throttle valve servo must be repaired.
A collapsed air filter doesn’t just bring in dirt, but also things like snow, which can shock the hot wire inside and mess with the MAF sensor, causing the engine to shut down as well.
