dev1360
Alright, if you have been following along in the UPR thread, you know that we have been waiting for my dyno appointment to test the PMAS intake back to back with the stock intake on the same dyno, on the same day. The results are in, but first, a bit of background.
Purchased the PMAS from Lethal Performance. They had the best deal, hands down. Free shipping alone made it the best deal. Used their standard forum discount for a bit off.
Installed the "no tune" PMAS and logged the supplied MAF with my tuner. He was impressed at the very clean and smooth MAF signal, and confirmed that there was no "trickery" happening with load factoring with the different MAF. No changes to the tune were necessary.
I initially installed the unit with the MAF down inside the shield. This left a gap between the bottom of the MAF housing and the shield IATs were sky high. Consistently, even at highway speed and WOT I could only get within 12-15* of ambient.
I have since turned the MAF to face upwards, while still inside the shield. This has allowed me to turn the filter down into the shield, more in line with incoming air, and has also better sealed the shield against the MAF housing. Intake temps have dropped significantly. I am seeing within 4-9* of ambient while cruising. Temps while sitting have dropped approximately 20* also.
My car has a flex fuel tune (done by Mike O'Grady of OG Tuning), X pipe, GT500 mufflers, 170* thermostat, and of course the PMAS. Car is currently on E77.
Dyno runs were done at Pur Performance in St. Charles, MO on 7.7.16. Weather was stormy and high 80s for temps. All runs done on a Dynojet with SAE correction factor. NO changes to the tune, at all.
First run was made with the PMAS on, hood open. Intake temps near ambient.
Second run was done with PMAS and hood closed.
Third run was done within 5 minutes of the other two with the hood open and the stock intake.
Results:
Hood Open 415.45hp/386.5tq
Hood Closed 412.94hp/387.71tq
Stock intake 401.40hp/379.70tq
I think it's important to note that dyno numbers can vary wildly, even between the same brands. Less important to look at the total, but the change.
This is a quick video I threw together on my phone. There will be a more comprehensive, and much better produced, video coming from Bad Bowtie Productions on YouTube. He was there dynoing his 2016 SS today. (410whp/423wtq)
[ame]
Results:
[ame]
