Please educate me on pcv/catch can/ breather setup
Dennisn
Chicagoland
16 gt
So I'm redoing everything for the winter and adding a catch can/ breather setup. It will not recirculate. So drivers side has no restriction from the factory. Thus why I'm getting all kinds of oil on valve cover. (Was running breathers only) Pass side has some sort of check valve in it but it's not a true check valve. It will allow air to move both ways but is definitely restrictive.
What kind of setups you guys running. Plan on 15 plus lbs of boost.
Want to basically run lines from both valve covers to breather/catch can but don't know if I need any type of check valves so I don't pressurize something wrong.
Twin turbo setup if it matters.
