- Sep 14, 2020
- Wellington, FL
- Jake
- 2022 F-150 RCSB 5.0
Hey all!
Pedders Suspension just released their all new Extreme XA Supercar Coil-over Kit for all S197 Mustangs!
This kit is a fully adjustable and tunable coil-over setup. For the front, you get their eXtreme XA Remote Canister Struts with Pedders Front Sway Bar links.
For the rear, you get their eXtreme Rear springs, adjustable perches, and of course, their fully adjustable eXtreme XA Remote Canister shocks.
With previous Pedders Extreme XA systems for the SN95 and S550 Generation, it’s safe to say this kit is the premium suspension system that is every handling-built Mustang owner’s dream!
All four corners feature a Remote Canister, which allows separate bump and rebound adjustment, making these one of the most versatile and adjustable shocks for the S197 Platform.
A few features Pedders Highlights:
• Gas pressurized
• Fully threaded mono-tube body
• Factory style bracketry
• 30 position bump dampening
• 30 position rebound damping
• Remote canisters
• 52mm threaded body
Front Spring Rate: 7 kg/mm
Rear Spring Rate: 5 kg/mm
Note: Boss 302 Mustangs will need to purchase standard Mustang GT rear upper shock mount bushings and hardware from Ford.
Check them out for yourself here!
SHOP NOW | Pedders Supercar Coilover Kit (2005-2014 Mustang) | Lethal Performance
Of course, if you have any questions or want to get something on order, feel free to reach out to any of us here at Lethal Performance!
