Paxton hitting hood
asylum938
pa
18 Mustang GT
Just finished up my Paxton Install and in the directions it does say you might have to trim the hood blanket for clearance.
I did that and I can get the hood to close but it's definitely still hitting the hood, I have to push down decently hard to close the hood
Anyone else have this issue?
Laztug
Wanna run dyno slips bro?
COTUS
Calling out OKC #1 spot after axle back install.
let the hood drop from about 4-5 inches. The hood does not easily push close.
BlackGT
Southeast TN.
2015 triple black GT convertible
I had the same issue with mine. I removed the hood insulation and put a small washer between the latch on the hood and the hood and adjusted the hood stops up a tad. I have about 1/8th inch clearance between the top of the flute and bottom of hood.
Demon Coyote
Naperville, IL
2015 Mustang GT
I did something similar, put two washers on each stud between the hood and the hinges to prop the hood up a little bit. I also re-adjusted the latch in the front by moving it up and about so the hood can close easier. I also did some testing by putting a decent layer of polish on the highest part of the super charger (not too thick of a layer) and closed the hood from different heights to confirm if it was still hitting or not. Everything worked out OK once I made those adjustments, but mine was definitely hitting before as it took a tad bit of paint off the hood. Hope this helps!
BlackGT
Southeast TN.
yea, of all things, I used my kids silly putty across the top of the blower to measure clearance.
AutoX_GT
Columbus, OH
2015 Mustang GT Performance Pack - Black
That's weird, mine cleared even with the insulation on. There is a small indentation in the insulation, but fits just fine..
beefcake
Bethel
2018 Ford Mustang
You may need to clock the head unit so that it is more flat across the top
